HK AVR-520 and Multi Room
Discussion in 'AV Receivers' started by Bob_Lawrance, Jun 9, 2006.
  1. Bob_Lawrance
    Bob_Lawrance Stunt Coordinator
    Apr 14, 2002
    163
    I was wondering how hard it is to use the multi room function of the avr 520.
    Has any one ever done it?
    What do I need to do it?
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,853
    52
    9,110
    Bay area, Ca
    Gene
    I own an H/K 520 and while I haven't done multi-room you will need an external two channel amp (or receiver) and cables/speaker wire to hook it up with, and a remote IR and wire for the supplied multi-room remote control. You can also use the main remote if you wish (or none at all). To activate it, go into the OSD's main menu and choose "Multi-In" and change from Off to On. You can also select the input source and volume from the OSD if you choose not to use a remote. See page 16 for installation and 36 for operation. If you don't have a manual you can down load one from H/K's web site via AdobeAcrobat. I always thought it was alot to go thru but I'm sure it's less complicated than it looks once you get it all hooked up. Hope this helps.
