Robert Hoffman
- Mar 9, 2001
I've recently added SACD ability to my 2-channel system and I've got a question regarding my HK 230. Is it necessary to use the 6 channel direct inputs to realize the benefits of stereo SACD? It would be nice not to, because then I can still use the HK for bass management (really just adding some sub to my fronts, set on large). Furthermore, I can't imagine why I would need to use the 6 channel inputs when the normal analog inputs have a stero bypass mode which should simply pass the analog signal anyway.
If it matters, I'm using a Denon 2900 as the SACD player.
Rob
Rob
