Hello,
I bought a second hand Harman Kardon AVR 10 about one year ago through Ebay. Overall, I am satisfied. Although it says it will pump out only 35wpc, it is plenty for me, driving Boston Acoustics A40.
There is a thing that bothers me. First, the receiver seems to be quite warm while it is in standby. Receiver is cool if I turn the switch to "off" position. Whether I keep the receiver in standby or playing it for a few hours ( I do play at low volumes, the volume dial is at around 9 o'clock direction), it seems to be at around the same temperature. It appears to me that the "standby" just means turning off the display and disable the control buttons only, and keep the receiver on with full power on its active circuits, or I have a leaky capacitor somewhere.. I understand the receiver can be warm in standby, but how warm is normal? I did consider an entry level onkyo (502), but that one didn't even have a "off" button, so I assume it wil have the same problem.
Is the "standby" more a thing for higher end manufacturers? I also have a yamaha receiver, which I can hear a "click" when I turn it on and off, and will stay cool when I turn it to "off" position using remote control... Obviously the H/K does not do that. It goes to "standby" to "on" mode instantly, without a click... and does not respond I turn the switch to "off".
I would appreciate advices. Thanks in advance..
