HK 525 x-over question (1 Viewer)
i have an hk 525 and i cant seem to get it to let me change the x-over points for each speaker....i go into the set up menu on screen and it only lets me change the lfe x-over point.
anyone with this unit or that has any ideas it would be greatly appreciated.
i have read throught the manual and cant seem to get it to work again...
i set them once before i had any sub hooked up cause i wanted my towers to put out a little bit more bass..
HELP!!!
JohnnyG
How are your speakers configured? If they are all set to 'Large', you can't adjust their crossover points because you're not asking for the bass to be crossed-over. Also, make sure you're not in straight analog mode because you can't adjust the speaker type in that mode. Switch to Analog DSP mode.
JohnnyG,
Thank you very much..it worked just like you said it would...i had my speakers set to large cause i wasnt using a sub when i first got it.
I just got your reply today thats why the delay in thanks.
MBH
