HK 520 for music
Discussion in 'Archived Threads 2001-2004' started by brian reis, Jul 12, 2002.
  1. brian reis
    brian reis Extra
    Jun 28, 2002
    23
    I just hooked up my 520. I've heard great things about the 520 for 2 speaker music. Mine has too much bass. I have my powered sub crossover turned all the way up.
    My OSD doesn't let me choose anything for the front speakers. The only thing I can change is Sub none or Sub (L+R) with crossovers of either 40Hz or 60Hz.
    Also a little too much bass watching dish TV. Currently have sub at 80Hz crossover. 100Hz should make it worse, right? Guess I could turn the bass knob on the receiver down. Or maybe turn volume on sub down. Any suggestions?
  2. Jeff Savage
    Jeff Savage Second Unit
    Aug 21, 2001
    386
    I own a HK510 and I had a simlar issue until I calibrated using VE. After that everything was fine. Have you ever set up your system using a setup disc? If not you really should. If you have then write down the settings for the l, r, and sub and transfer them to the 2 channel input that you are using. That would be a good place to start.
    Otherwise if you have your powered sub set up at the volume level you like for movies then just go into the menu when you are on the source you use for music and lower the subwoofer level (or increase the main speaker level) until the bass s where you like it.
    The HK's store these settings per input so changing a level on the CD Input for instance will not change the values for DD or DTS. Do the same for the video input that you are using for the Dish.
    Hope this helps,
    Jeff
  3. brian reis
    brian reis Extra
    Jun 28, 2002
    23
    I started to put the sub level in the negatives last night. I will continue to do that.
    Weird thing is that in 2 channel stereo, OSD won't let me scroll to the front speakers (it just has --- next to it). Only sub settings.
  4. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    Excellent input Jeff!![​IMG]
    Also, let's not forget the old speaker placement issue if he still has problems with too much bass.
    Good Luck
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Yes, turn the sub down at the sub first, then adjust with the controls on the receiver. What type of sub, frequency response, power etc... Have you already done EZ set with the remote?
  6. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    With analog input, the front speakers are always set as 'Large' and this cannot be changed.
  7. TomMadden
    TomMadden Agent
    Jun 23, 2002
    31
    I moved my Sub out of the corner of the room into a more central placement. What a difference that simple act made! The sound is much less boomy and much more controlled. I was all ready to blame h/k, too!
