HK 435/635 question!
Discussion in 'AV Receivers' started by DavidCooper, Dec 12, 2005.
  1. DavidCooper
    DavidCooper Stunt Coordinator
    May 21, 2004
    230
    How can I play full stereo out of this thing? I want to play my mains full range stereo witout the sub when listening to music. When I select stereo it still keeps the sub. Any HK owners out there?
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I know many receivers have an option called "Direct" where the receiver bypasses all bass management. I would look for this button/feature and see if that helps. If not you might also try checking the manual until someone here posts. Hope this helps [​IMG]
  3. DavidCooper
    May 21, 2004
    230
    Oh I've been through the manual plenty of times and the feature that I want is "stereo" mode. It supposed to bypass the sub but it doesn't.
  4. MikeNg
    MikeNg Second Unit
    Jan 22, 2004
    440
    Set your L/R channels to 'large'.
    I assume you are using the sub out channel to feed the subwoofer.
  5. LanceJ
    LanceJ Producer
    Oct 26, 2002
    3,168
    David: If it helps any IIRC the previous model, the AVR630, did what you're looking for.
    In that receiver's onscreen (OSD) bass management menu, there is an option labeled "global" and "independent". If you set it to global, when you choose "subwoofer-yes", EVERY source will activate the sub output. But if you set it to independent, only that source you *specifically* choose to have "subwoofer-yes" will activate the sub output (I think the source to be configured is the one that was chosen immediately before the OSD was activated, but am not sure about this).
    In other words: choose the CD input first, then pull up the b.m. OSD, choose "independent", then choose "subwoofer-no". I think that should do the trick; otherwise I would email/call Harmon themselves.
    We rarely messed with the 630's b.m. system during those six months, since we always ran all speakers large [​IMG] + subwoofer-yes.
  6. DavidCooper
    May 21, 2004
    230
    Sounds good...I'll take a look tonight.
