HK 325/525 adding 2nd sub
Discussion in 'AV Receivers' started by Hank Edwards, Jun 19, 2003.
  1. Hank Edwards
    Hank Edwards Extra
    Jun 5, 2003
    19
    Hello all,
    I was wondering if anyone here has either the HK 325 or 525 and has a 2nd powered sub hooked up to it. If so did you use a Y splitter in the sub pre-out, and was the addition quite noticible. what is the best way to add/hookup a 2nd powered sub with either of these recievers.
    Thanks in advance, and all oponions are welcome.
    Subs: SVS 25-31, and Klipsch KSW-10.
    Hank
  2. RickBlacker
    RickBlacker Stunt Coordinator
    Apr 30, 2002
    133
    Well, I had the 520, and now I have the 7200, what I would do if I were you, I would get a Y splitter directly out of the sub pre out. Then run a sig to each sub.
  3. Hank Edwards
    Hank Edwards Extra
    Jun 5, 2003
    19
    I was told on another thread that a splitter would lower the signal to each sub, and volume would be lost. Will the loss be significant, or will I still hear and feel the effects of a 2nd sub? Would I be better off buying one bigger sub and using it alone?
    Hank
