HK 225 or 320
Discussion in 'Archived Threads 2001-2004' started by PeteSaccuman, Dec 13, 2002.
  1. PeteSaccuman
    PeteSaccuman Auditioning
    Dec 12, 2002
    2
    I'm purchasing a HT system, and would like to hear what people have to say regarding the HK AVS 225 vs. the 320. The 320 can be had for $399, the 225 for $359.
    Is there any significant new technology in the 225 vs. the 320? Are there any significant differences besides power output?
    I'm a HT neophyte, want a decent sounding HT system, but I'm not looking to build the end-all system. System will be used mostly for HT. Thanks.
  2. Rick_FL
    Rick_FL Stunt Coordinator
    Dec 4, 2002
    171
    get the 320. go to crutchfield.com and you can compare the two.
  3. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    I have the 225 and love it. I can't believe the 320 is down that low- a real deal if you ask me. I would have gotten the 320 if I were in your position, though. I think it has a better upgrade path if you choose to do so in the future. If you know you won't add external amps or anything like that-the 225 will be just fine, but one never knows does one?
