JohnGoggan
- Aug 14, 2002
I calibrated my new 57UWX20B today using Avia. Using the blue filter, I had no problem setting saturation and hue and getting it just how I expected it to be. I then checked the color decoder test. With the blue filter, it is right on, as it should be. With the green filter, it is about -5% to -10% -- which doesn't bother me. With the red filter, it is at +25%! I appear to have an extreme red push problem.
I can try to compensate just using the normal saturation control, but to get it even to +15%, I really end up putting my blue out of whack.
I have too many varied inputs to make an attenuator type of adjustment. Is there a service menu option to try to fix this maybe?
Thanks!
- John...
Thanks!
- John...
