Hitachi 51SWX20B
Discussion in 'Archived Threads 2001-2004' started by Little*John, Jan 12, 2003.
  1. Little*John
    Little*John Auditioning
    Jan 1, 2003
    5
    I'm thinking of purchasing this set. A couple of questions, please.
    What is 3:2 pulldown?
    How does one select between 1080i, 720p, 540p,480p,480i on this TV or any other? Does the set automatically do this, or is it user selected (and how)?
    Should I put questions like this in the basics forum?
  2. dpippel
    dpippel HTF Premium Member
    Feb 24, 2000
    5,055
    1,401
    9,110
    Yoyodyne Propulsion Systems
    Doug
    Little John - 3:2 pulldown is a complex subject. If you use the forums search function you'll find more than enough reading on the subject to keep you busy.
    The 51SWX20B only displays two native resolutions - 540p and 1080i. Anything else is upconverted. Again, using the search function here will produce a ton of info on this subject. It's been thoroughly discussed. You'd also be well served by checking out http://www.avsforum.com/. Lots of info there on Hitachi sets.
