Hitachi 43FDX10
Discussion in 'Archived Threads 2001-2004' started by Chad Ferguson, Oct 14, 2001.
  1. Chad Ferguson
    Chad Ferguson Supporting Actor
    Oct 31, 2000
    923
    Wondering if anyone had any reviews of this TV? The main purposes are for my Xbox at 1080i and DVD's to look there best. Does this unit do the squeeze resolution thing so that all the lines are between the widescreen bars? Here is a link for anyone that is interested: http://www.futureshop.ca/catalog/pro...=&newdeptid=11
    [Edited last by Chad Ferguson on October 14, 2001 at 12:48 AM]
  2. Massimo N
    Massimo N Stunt Coordinator
    Oct 23, 2000
    174
    Hi Chad,
    I believe this set cheats with the squeeze mode. I believe the set will downconvert a 480p/1080i into a 16/9 window. You will notice that the set will still have grey bars on top and bottom when displaying a HD or 480p signal. So it does not re-adjust the raster on the CRTs.
    I'm sure I've read other posts on this site about this set. Try a search on 43FDX.
    Cheers!
    Mass
