Highest Bit-rate you've seen (1 Viewer)
Mark McLeod
What is the highest bitrate you've seen on DVD. I've been doing some comparing and one disc had a 9.9 Mb/second average bitrate. Is that even possible or did the program just measure it wrong.
M.
Bruce Hedtke
That sounds wrong. High contrast scenes might push that bit-rate up to 8 or so...but a 9.9 average? Sounds fishy. Most discs I've bothered to check seem to hold at 4.5 to 5.5 in normal lighted scenes.
Bruce
Iain Jackson
The Usual Suspects SE (Region 2) - 9.25 Mb/s average bitrate. Taking into account the four soundtracks, that's still over 7 Mb/s just for the video.
Patrick McCart
Georgia (the state)
Patrick McCart
City Lights (Image) is almost always above the 9.0 MBS line and often right at 10 MBS.
It sure does show...while the elements used have a few scars, I didn't see a single instance of edge enhancement, nor did I see any other digital artifacts. This is VERY impressive for a 1992 master of a 1931 film. :)
yacubjkc
