high-pitch noise from brand-new TV? HELP!!
Discussion in 'Displays' started by ChrisLazarko, Dec 20, 2003.
  1. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Hi, my cousin bought a 32" TV for his girlfriend and we just hooked it up. It's a Sharp TV. It makes this high pitched noise that just drives us crazy. Now is this from it just being a new TV or what?
    Thanks for any help anyone could provide.
    http://www.sharpelectronics.com/prod...8,1157,00.html
    The link to the TV is above. Thanks for any quick responces or anything of help!
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    How high pitched? There is a very high pitched whine that standard tvs make, and always have. Most people either ignore it, don't notice it, or can't hear it. IF this is not what you are hearing, then there may be a problem.
  3. ChrisLazarko
    Aug 13, 2003
    867
    hmm well it's pretty much gone now. I guess it was since it was brand-new it was making this noise. Oh well, no big deal.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    This whine you're hearing, as Chris notes, is normal. And it's at higher than 15 kHz, which at least demonstrates your hearing is in decent shape (I can tell when a TV is on in any house, even if it's sound is turned off and the unit is in another room). It is more shrill at first, and levels off a bit as the set warms up and its internals reach thermal stability. The set's fine, like your hearing.
  5. ChrisLazarko
    Aug 13, 2003
    867
    Hmm well that is good to know. =)
