tim_r_s
- Jun 1, 2004
Has anyone run across this problem:
I have a widescreen HDTV connected to an HDTV receiver digital cable box using the DVI/HDCP connection. Everything has worked flawless for several months. Last week, I turn on the TV and nothing but black. When I changed the TV/Video to other settings (like DVD player, Xbox, etc) the picture was fine - I was just not able to get a digital signal.
After calling my cable company and verifying that my digital receiver and the TV cable was ok, I found that if I removed then reconnected the DVI cable, the picture would return and show the following message on screen for a few seconds:
"The HDCP of your display has been compromised. Please use YpbPr outputs for your HD connection."
So now, everything I turn off the TV, then turn it back on, I have to go through the process of removing and reconnecting the DVI connection to get the picture.
Any thoughts??
Any thoughts??
