High Def DVD audio, time to upscale
Discussion in 'AV Receivers' started by JackKay, Feb 14, 2005.
  1. JackKay
    JackKay Second Unit
    Mar 27, 2004
    461
    With Blu Ray and HD DVD coming, does anyone know yet if I will have to replace my receiver to Max out on the new format? They are several years old, but work 100%.
    thanks Jack.
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    You won't have to for it to work, it appears, since there will be some existing lossy codecs used(DTS & DD), but you will need a new one if you want to reproduce either the higher quality lossy(DD+)or highest quality lossless tracks(MLP & DTS HD).
    DJ
  3. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Also, if the players have multi-channel analog audio outputs then you might be able to access the DD+ / DTS-HD / MLP tracks for higher audio quality without upgrading your receiver. This assumes that they will be available with analog MC outputs.
    Cheers,
  4. Stan Rozenfeld
    Stan Rozenfeld Stunt Coordinator
    May 27, 2000
    197
    How many channels are we talking about? Is 7.1 set up will be the standard for hd-dvd and blu-ray? And how will these new lossless codecs accomodate a 5.1 speaker system even if you have the newer receiver?
    Stan
