hiding wires form sides?
Discussion in 'Playback Devices' started by Jeremy Scott, Jan 2, 2004.
  1. Jeremy Scott
    Jeremy Scott Second Unit
    Mar 29, 2003
    292
    The cheap cart that i had my reciever, dvd player, and gamecube on was about to break so i bought a cheap $80 audio stand from walmart.
    I was not really sure of what kind i wanted so instead of paying $100+, so i picked this up for now.
    It matches my 36" HDTV and stand pretty good, but you can see all the wires from the side which is annoying.
    is there any way to cover them up?
    I thought maybe setting a crawling plant on top and letting it come down the sides.
    any other ideas?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Have you read my How to hook up your new HT reciever thread?
    Reciever on the bottom helps by letting the speaker wires flow onto the floor.
    Now you can bundle the interconnects with black-plastic tubing (split-loom) from Radio Shack to give it a better look.
  3. Jeremy Scott
    Mar 29, 2003
    292
    so you are sayingt o put my reciever on the bottom shelf, about 1 inch off the floor?
  4. TylerZ
    TylerZ Stunt Coordinator
    Dec 3, 2001
    214
    You can also pick up that split corrugated plastic tubing from Home Depot. It comes in three sizes (diameters) for different size wire. Look in the electrical dept. It really cleaned up the way my speakers wires look running up the stands.
  5. Bob McElfresh
    May 22, 1999
    5,182
    Yes. There are about 5 small reasons for this. It's not worth it if you already have everything wired up. But the reciever on the bottom helps organize the cables a bit more naturally and simplifies getting to the other devices.
    You want 3 separate bundles of wires:
    - AC power wires
    - Speaker wires
    - Interconnects
    Putting the receiver on the bottom lets the speaker wires flow out/away from everything else. Now you just have to organize the AC power cords, and interconnects.
