Hide mp3's and zip's inside GIF's
Discussion in 'After Hours Lounge (Off Topic)' started by Patrick McCart, Feb 21, 2006.
  1. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,566
    195
    9,110
    Georgia (the state)
    Patrick McCart
    If you have Windows, you can actually hide an mp3 within a GIF animation (or just one image) by using a simple command. All you need is Winamp and WinRAR
    First, put the GIF and the mp3 (preferably, you want the combined size to be under 1 MB, so keep that in mind) in the same folder. The easiest is the desktop...
    If you're going for files on your desktop, you do this:
    - Open the command prompt
    - type "cd desktop"
    - Then you can combine...
    "copy /B yourimage.gif+yoursound.mp3(or yourfile.zip) yournewfile.gif"
    Using Winamp will always work for the mp3's...
    [​IMG]
    Drag this GIF into Winamp and play it (you can copy the url and put it in "Open URL" too).
    Here's a ZIP example:
    [​IMG]
    Save this to your HD as a zip and then extract it with WinRAR. (You'll need Windows Media Player to play the WMV).
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Wish we found out about this in 1996. [​IMG]
  3. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
  4. Daren Welsh
    Daren Welsh Supporting Actor
    Jan 16, 2002
    660
    I'm not sure I understand. How is this any better than simply changing songfilename.mp3 to songfilename.txt for storage/sharing/transfer?
  5. Chris Lockwood
    Chris Lockwood Producer
    Apr 21, 1999
    3,215
    Yeah, why exactly would you want to do this?
  6. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    LOL - If only we could embed Midi files! That would be groovy!
