Hi Powered Amps? How to check for TRUE power?
Discussion in 'Archived Threads 2001-2004' started by Bill Johnston, Dec 4, 2001.
  1. Bill Johnston
    Bill Johnston Stunt Coordinator
    Nov 20, 2001
    77
    Ok, I know that these might seem like annoying beginers questions... But... I'm looking at a Kenwood @ 100 to 110 watts versus an Onkyo @ 75 watts... Everyone says that the Onkyo is more HI DRIVING POWER?
    Is there a way from the specs of the products to see which one has more REAL POWER?
    Like... Watts x Amps = xxx
    Thanks!
    Bill
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    First .. go by the stats
    20-20000 HZ 100 watts at 8 Ohms. if they both say that Cool
    Rememberr that the max dif between 75-100 watts is 1db ..don't sweat it.
    If you can find out about damping and more importanty current draw and capaciters(how many MFD they contain) it will give you a better idea.
    If you are using a powered sub and bookshelf speakers .... I wouldn't worry
    Ony worry if the speaker are a hard draw ... lookup Paradigm Ref100s they don't come to life without lots of juice
    As long as it is rated "all channels driven" 20-20 000HZ you'll be fine.
    If they say "one channel driven @ 1000 HZ" I say divide by 2 ... A 1000 HZ signal is VERY easy for an amp to drive. So that 100 watt amp would be 50 watts
    Brent
