Hi! New here with a ? about zoning
Discussion in 'Archived Threads 2001-2004' started by Veronica, Aug 13, 2002.
  1. Veronica
    Veronica Auditioning
    Aug 12, 2002
    4
    Hello Everyone!
    Hope you can help me out with my query.**I live in Australia.**We are in zone 4.**I purchased a Pioneer dv 344 player.**I bought some dvds from the UK which are PAL zone 2 which play fine on my player.**I have a dvd which I bought here but is NTSC zone 4 which is fine.**I am thinking about buying an 'Are You Being Served' dvd from the US but it is zone 1.**(I cant get it from zone 2 or 4)**Do you think it will work on my dvd player?**
    Thanks for your time
    Veronica
  2. Hartwig Hanser
    Hartwig Hanser Second Unit
    Oct 9, 1998
    300
    110
    Hi Veronica,
    short answer: no.
    long answer: I assume, that your player has not been modified to be codefree, right? That means, it can play only region 4 and region 0 (= no regional code) discs. Now, many DVDs sold in Australia are identical to those from Europe and contain code 4 AND code 2, althought only one of them is displayed on the box. This is the reason you can play your UK dvds - you were lucky to buy just some of those that are also code 4.
    Unfortunately US discs are code 1 only, therefore you will most probably be not able to play them unless you get your player modified to be codefree (which costs money and you loose your warranty).
    Hartwig
  3. oscar_merkx
    oscar_merkx Lead Actor
    Apr 15, 2002
    7,626
    Hi Veronica
    Welcome to the Forums, just send you a PM for more info about your Pioneer as I have the same one, although mine is MR.
    cheers
    Oscar
    [​IMG]
  4. Justin B
    Justin B Agent
    Dec 20, 2000
    32
    Welcome to the HTF, Veronica.
    Your DVD player may very well be region-free, depending on where you bought it and how much you paid. Some retailers sell modified Pioneer dv344 players. These are identified by a 'green dot' sticker on the box. If it had this sticker, you'll be able to play R1 disks. Otherwise, you can get the player modified. Perhaps you can borrow an R1 disk from a friend, or even hire one, to find out either way?
    If you do need to (and want to) modify your player, Campsie HiFi in Sydney can do it for between $100 and $180 depending on the type of mod.
    Also, if you're not already aware of it Michael DVD is a great site for R4 DVD information, including comparing R4 releases with other regions.
  5. Sam Owens
    Sam Owens Stunt Coordinator
    Mar 9, 2002
    122
    And [shameless plug]pop along to DVDPlaza while you're at it for more friendly R4 advice[/shameless plug].
    As Justin B said, most Pioneer players sold in Australia are region free - look for the green dot and you'll be right.
    Anyway, what R2 titles do you have, and which studios release them? Fox, Warner and Columbia tend to release dual-coded stuff.
  6. Veronica
    Aug 12, 2002
    4
    Hello again!
    When I bought my dvd player I was told it was multi-regional. So what does this mean?
    Veronica
  7. oscar_merkx
    Apr 15, 2002
    7,626
    that you can play R1 discs after all
    [​IMG]
  8. Veronica
    Aug 12, 2002
    4
    Thanks!!!
    I hope it wasnt just a sales pitch though ;o)
    Veron
  9. Mark_vdH
    Mark_vdH Screenwriter
    May 9, 2001
    1,035
    What Oscar said...
    As long as your TV can display NTSC signals (and, looking your first post, it can), you can watch all R1 discs.
    I think that your model Pioneer player can't automatically switch regions (at least the equivalent R2 model can't). It has to be done manually. If that's the case, be sure to know how to switch regions (usually a button-press combination on the remote).
  10. oscar_merkx
    Apr 15, 2002
    7,626
    Hi Mark
    Seeing that Veronica has the same model as I do in regards to being Multi Region, the disc will automatically play
    [​IMG]
  11. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,375
    16
    610
    "on a little street in Singapore"
    Yee Ming Lim
    my guess is if you were specifically told it was multi-region, it is. here in Singapore practically all players are multi-region (a.k.a. "code-free"). one of the "benefits" of not being in the all-mighty Region 1, since we want to play R1 discs, our players tend to be multi-region, whereas our R1 friends generally have players limited to R1 only.
    having said that, note that some so-called multi-region players can't deal with R1 discs that are "region code-enhanced", RCE. but Pioneer is generally not one of the brands that can't deal with RCE, i.e. your player should be able to deal with RCE discs without difficulty. but as someone earlier suggested, michaeldvd.com.au is a useful resource.
  12. Veronica
    Aug 12, 2002
    4
    Hi all!
    Ive been looking for the green dot but cant seem to find it. I think I will go ahead and but the R1 disc. If doesnt work well so be it. At least I'll know.
    Thanks for all your help
    Veronica
  13. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,421
    313
    9,110
    Cees Alons
    Veronica,
    As said before, even when it's not modified yet, you can have it modified.
    And, oh, please let us know what you find out about your player!
    Good luck.
    Cees
