Ted_Polzin
- Aug 12, 2002
I think I have the same painting problem you had on Sonosub III. I used Black enamel, I spent a lot of time wet sanding etc and on my last coat it gave the same bad finish
Anyways here is what I did
Sand and fill the MDF.
Prime.
Sand and fill more
Prime.
Wet sand Primer.
Paint black.
up to this point it was awsome .. and about 7 days worth of work. I then wet sanded the black paint and right away I got that awful finish. This was ALL with enamel. Same brand for both the back paint and primer.
Anyways long story short. I would love to know what happend, but anyways I bought some textured paint and will go that route. Kinda upset about all the time wasted but oh well.
Ted
Prime.
Sand and fill more
Prime.
Wet sand Primer.
Paint black.
Ted
