scott>sau
- Jul 1, 2003
Russ Herschelmann gave a good CEDIA speech on multiple subs from his "Home Theater: Essential Elements".
"As a general rule use twice as many subs as you think you need."
"Multiple subwoofers placed asymmetrically to yield smoothest bass response." I can send you a scanned pic if you want of the placement . Basically he has a sub front left corner and the second sub mid-to-front right side (staggered, lack of balance).
Dual subs in proper positions reduce standing waves.
Doug Osbourne of M&K Pro suggest two enclosures stacked in the front corner. Avoid center of the room placement. Place subs in the first half of the room.
Hope this helps
Hope this helps
