Brett Creider
- Oct 7, 2003
The amp has already been ordered, as well as the driver...
Parts Express 250watt Remote Control amp
Adire Audio 15" Tempest
I've looked around at local hardware stores and based on the materials they sell I've planned on the old fashioned MDF box...
It shall be 24"x24"x24" give or take. The MDF is sold in 24" x 48" peices for $7 each...3/4" thick...so here is what I plan...
(All attachments using ProBond + Wood Screws)
1) Buy 4 MDF 2x4's...
2) Cut each MDF in half to create 8 2x2's...
3) Cut 1 side each of 2 2x2's by 1.5" (3/4" x 2)
4) Take 2 2x2's to make base, cut a 15" hole in one and a 16 in another (I am not sure on the actual measurements but I'll get exact ones when the driver arrives. I am just going to do a flush mount using double thick MDF like I've seen done before, so don't take the hole measurements too literally)
5) Take 1 2x2, cut it in half to a 2x1. Make 8 3" x 1.5" peices. Use 2 peices each to make 4 90 degree angled legs. Attach legs to base. (Maybe use some MDF left over from holes to brace legs?)
6) Take the other 1x2 and make 4 24"x3" braces, 2 going either way.
7) Mount driver in base. Cut out hole for remote and amp.
8) Start attaching the front and back. Then the 2 sides will fit in between those. All 4 peices attached to top of base.
9) Fill with some insulation/filling stuff I saw at Wal Mart after I wire it all up. Attach top.
10) Have fun.
Sound good? Should only cost $45 to build the box and I'll laminate it or paint it later....
10) Have fun.
