heres another brainer
Discussion in 'After Hours Lounge (Off Topic)' started by DaveNel, Feb 6, 2005.
  1. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    Just to show how the brain works[​IMG]
    Follow this Exactly
    Count outloud 1,2,3,4,5
    after you do that go to the next setp:
    Now count the exact number except dont count the number 3
    Dont say it, dont think it, Dont let it enter you brain:
    Count outloud 1,2,4,5
    After you have done this go to the next step:
    The next step is pretty far down, Scroll to see the answer:
    OK Now if you counted 1,2,4,5 without saying or thinking the number 3, You failed the last step:
    Because in the back of your brain there was a signal sent to skip the number 3. Remember dont say it, dont think it.
    Your brain works and processes things we arent even aware of.
    Pretty weird huh..
  2. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    Yeah the brain and its Territories inside you mind is awesome.. processing info that you didnt even know that was going on.
    Your Sub-concience brain does it all processing millions and millions of peices of info 24-7 even in your sleep..
  3. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,261
    1,642
    9,110
    One Loudoun, Ashburn, VA
    David Fischer
    Dave, are you talking to yourself online? You're responding to yourself in your threads. [​IMG]
  4. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    (LOL) Im bored
  5. James T
    James T Screenwriter
    Aug 8, 1999
    1,643
    :lol I never would have noticed the talking to yourself part.
  6. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    And we're only using something like 10% of its capacity.
  7. Hartwig Hanser
    Hartwig Hanser Second Unit
    Oct 9, 1998
    300
    110
    This is a myth, despite it is heard very often. All evidence of modern brain research indicates that this number is false. Yes, the brain has a lot of redundant elements, but we need those for its function.
    And before somebody quotes Einstein: The man never said this!
    Now, if somebody would say, that most people could improve their thinking and their memory, that would be probably true. But several experiments show, that the brain works LESS when it is working better: with exercise it gets more efficient.
  8. Chris Dias
    Chris Dias Stunt Coordinator
    Nov 26, 1999
    180
    Toronto, Canada
    Chris
  9. MikeH1
    MikeH1 Screenwriter
    Oct 25, 2000
    1,492
    I guess I'm just not as intelligent as I thought. All this time I always just knew I had more potential
  10. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    I don't get the brainer. We either don't follow the first step or the last step? Plus that would be like saying "Now don't think of pancakes, don't even let them enter your mind."
    I'm now 100% sure everyone reading this is thinking about pancakes.
  11. Randy Tennison
    Randy Tennison Screenwriter
    Jan 5, 1999
    1,099
    Randy
    I'm not sure about this test. I didn't read it as a string of numbers, I read each number individualy, thus, wasn't thinking what the next number should be. In my small little mind, it was just four random numbers.
    In the rhythm I said the words, a "3" would have interrupted the flow, so it wasn't thought of.
    I don't know. Maybe I'm just weird . . .wired different.
  12. andrew markworthy
    Sep 30, 1999
    4,762
    12
    I think that the problem is akin to the following ancient and not remotely funny joke:
    DON'T READ THIS
    Some things are done automatically (the term in its technical sense describes something that requires no conscious attention to be performed) and they can't be escaped.
    Um, yes and no. Pedantically speaking, you become better at doing something with a high level of repetition/predictability because you develop automatic [see above] methods of processing the incoming stimuli and responding to them. But you are not necessarily becoming any more 'intelligent'as a result - you've simply learnt a heuristic. Of course if you learn lots of heuristics of the right sort then you will become more efficient at mental tasks and your cognitive performance will improve, so in that sense the argument is correct.
    Taking the argument a stage further, it also depends on how well organised your brain is. Generally people with more knowledge also have far more efficient storage and retrieval skills. The classic example of this is that someone with a large vocabulary will be able to retrieve the meaning of a word faster than someone with a small vocabulary. However, the person with the larger vocabulary also has a larger mental store to sort through. So the storage/retrieval mechanisms must be more efficient as well.
    And then you get the effects of normal ageing on all this (my area of professional expertise - supposedly), and that's where it really gets complicated.
  13. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
    My mind skipped over the Pancakes. Thanks a lot. [​IMG]
  14. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    (LOL) I don like pancakes I will skip an pass [​IMG]
