"Finds partitions automatically, even if the boot sector or FAT has been erased or damaged (does not work with the NTFS file system)"
Sorry to yell, but have more then a few people who've mucked up NTFS with this thing.
If it's NTFS, not a free solution, but a potential solution is to find a Windows System Builder and see if they will offer you the WinPE bootables to access any data.
DO NOT use PC-Inspector on the drive (or you may lose more then you started out losing!)
I posted a similar question earlier this week and asked for responses to a "Diskwarrior" equivalent for data recovery for NTFS. Independently I found two possible products, "GetDataBack for NTFS" ($69 or $79) and "R-Studio." In the end I went with GetDataBack simply because some noted it worked where R-Studio failed and I didn't want to pay twice.
I'm not completely recovered, but I am playing the AFC Championship in HD successfully from a recovery and copy. It takes about hours to scan a 200GB drive and then it takes time to copy the original files. The end result will also need a reformat of the original drive and possible copy back. Not nearly as efficient as Diskwarrior for Mac OS 9/X, which will recover to the same disk, but it meets my needs for now. I couldn't find anything for free to bring back corrupted partition info.
