Help! Yamaha or Denon w/ Paradigm 5.1
Discussion in 'Archived Threads 2001-2004' started by MikePeroni, Nov 29, 2001.
  1. MikePeroni
    MikePeroni Stunt Coordinator
    Sep 1, 2001
    180
    I have pretty much decided on Paradigm for my basement HT as they have great sound for the money. Now, no one carries Yammy, Denon and Paradigm together so looking for some advice. The system will be about 50/50 with DVDs and CDs. Im thinking Titans up front and Atoms for the rear. Have the receiver narrowed down between Yammy RXV620,RXV800 or Denon 2802. Now, the Denon has DPLII. Is this used for regular cable broadcasts to enhance them? Is it a big improvement over regular DPL?? The Denon also has DTS-ES which apparently is a true 6 channel mode(?). Any advice would be great as the features with the Denon are nice, but I want the best sound w/ the Paradigms. Thanx
    Ps. I thought the Denon remote seems big and cheap.
  2. Tom_Mack
    Tom_Mack Stunt Coordinator
    Dec 11, 2000
    233
    I have a Paradigm/Yamaha match for about a year now and hope to soon get rid of the Yamaha. Movies sound very good, but the receiver is not very musical at all in my opinion. Paradigm speakers are bright speakers and Yamaha receivers are bright sounding receivers. The mix of the two is VERY bright for music. Mid to upper bass responce is just OK. I have heard the Denon 3802 and was impressed with its sound, but I don't know how the 2802 compares.
    My system consists of:
    Yamaha RX-V596 receiver
    Paradigm Monitor 7 mains
    Paradigm CC-370 center
    Paradigm mini monitor surrounds
    Paradigm PDR-10 sub
    Good Luck!
  3. Nick G
    Nick G Stunt Coordinator
    Aug 12, 2001
    152
    Mike, I have an Onkyo 595 with Paradigm Studio 20s up front and Atoms as surrounds and I am very pleased. I think either the Yamaha or the Dennon would be fine as well. I personally dont find that receivers sound very different from each other so I would buy a which receiver has the features you want. If you are getting a sub too you might consider getting Atoms as both mains and surrounds. I find the Atoms clearer and more detailed than the Titans, but with less bass. If you have a sub to handle the bass, then I think the Atoms sound better. Just a thought, either way you will have a nice system. Enjoy.
    Nick
