help with xbconnect
Discussion in 'Gaming' started by BradleyS., Feb 16, 2004.
  1. BradleyS.
    BradleyS. Stunt Coordinator
    Jun 9, 2003
    206
    I downloaded the xbconnect thing but I couldnt get it to work. I had halo in and had it in system link mode where it says searching for games, Then I would go to the top box on the xbconnect main menu and double click on a game that I would want to join. It would say " searching for xbox" then take me to the setings menu. Whats my problem? I'm using a linksys wireless router so that could be a problem. i enabled the wet 11 box in settings though.
  2. LaMarcus
    LaMarcus Screenwriter
    Mar 7, 2002
    1,619
    Well, the way I connect mine is I use USB from the cable modem to pc NIC, and I use ethernet from the xbox to the Modem.
    So I make two lines coming right off the modem and that works fine. Another way is to have two NIC's in your pc.
  3. George Monroy
    George Monroy Stunt Coordinator
    Jan 3, 2001
    140
    If you need more help you can ask here: www.gamersrepublic.net
    Go to the video game forum and them to the help forum.
    Or you can go to the Xbox Live forum.
  4. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    I have the exact same stuff u have, the Linksys router and the WET11. Everything works fine on my end. If u haven't done it yet, u have to get the WET11 "configured" for the Xbconnect, i.e., hardwiring it to the PC, out to Xbox again, etc.
