Help with Video Signal
Discussion in 'Displays' started by NateC, Jun 19, 2004.
  1. NateC
    NateC Auditioning
    Jun 18, 2004
    6
    Is there a way to flip the video signal from regular RCA cables? Like some kind of adapter or something? I'm using an old projection screen and I don't think you can flip it on the projector itself. Thanks for your help.
  2. NateC
    NateC Auditioning
    Jun 18, 2004
    6
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    What kind of projector are you using? There should always be a way to reverse things on most projectors, if it's a digital projector it should be in a menu somewhere, if it's a CRT you need to flip the horizontal and vertical scan connectors as needed.
  4. ChrisWiggles
    Aug 19, 2002
    4,791
  5. ChrisWiggles
    Aug 19, 2002
    4,791
    Let me clarify that: If it's a CRT, and you are hooked up by RGB, I do NOT mean that you switch the horizontal and vertical syncs at the RGB connection.
    Inside the projector somewhere (again what projector are you talking about?) there will be connectors that feed the yokes that need to be flipped, or there may be switches or such. It will tell you in the installation or service manuals usually, and sometimes in the user manual. What model is it?
  6. ChrisWiggles
    Aug 19, 2002
    4,791
  7. NateC
    NateC Auditioning
    Jun 18, 2004
    6
    I think it's a Zenith Pro 880X. I'm not sure, I obtained it from a friend who works at a restaraunt, when they switched out to newer ones. It's pretty old, and I'm not very well versed in home theater. I'm not a stranger to electronics, so I wouldn't be afraid to open it and look around. Any tips? Thanks for the reply, btw.
  8. NateC
    NateC Auditioning
    Jun 18, 2004
    6
  9. NateC
    NateC Auditioning
    Jun 18, 2004
    6
    Wait, I found out it is a Zenith Pro 851X. Sorry I wasn't sure before.
  10. NateC
    NateC Auditioning
    Jun 18, 2004
    6
  11. ChrisWiggles
    Aug 19, 2002
    4,791
    See page 18 and 19 of the installation manual for the 900pro.
    you have a PM for link to the manuals if you don't have them already.
  12. ChrisWiggles
    Aug 19, 2002
    4,791
