help with universal remote
Discussion in 'Accessories, Cables, and Remotes' started by KaseyB, Oct 18, 2003.
  1. KaseyB
    KaseyB Auditioning
    Aug 10, 2003
    10
    Hi all...ok this is what I have...a Sd-43ht toshiba dvd/audio receiver home theater system, a phillips 55" widescreen hdtv, and a philips directv/tivo dsr6000 unit...what i need is a universal remote....I want the tv to be able to power on and off and to change channels...i want the dvd to do basica dvd functions, i want the receiver part to do basic receiver functions such as change volume (on it instead of tv), change inputs, etc, and i want the tivo to do all tv functions easily...anyone recommend a good remote for all of this? i've seen the one for alls might be good?? which one? and will these control a dvd/audio receiver combo unit? thanks, Kasey
  2. TylerZ
    TylerZ Stunt Coordinator
    Dec 3, 2001
    214
    Might I suggest the Home Theater Master MX 500. It should do all you requested and more. Even my 12 year old has no problem using it. A good place to find info on remotes is
    www.remotecentral.com
  3. KaseyB
    KaseyB Auditioning
    Aug 10, 2003
    10
    Thanks for the info..but I would really prefer something a little less costly....
  4. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    Try the One for All 6131. It has all the Tivo functions and can control basic functions of 5 other components as well. It does not have learning capability, so the only catch may be your Toshiba HT combo. However, you should be able to get it to work using both the Audio and DVD devices. If you need macro and/or learning capability, look at the 8811.
