Stan
- May 18, 1999
Have 36 inch Toshiba TV purchased in 1997, works great, no problems, however remote is starting to fail, new batteries don't help.
Sticky buttons, some don't work at all. I'd like to open the remote and see if I can just clean the connections and clear up the problems. However, I have no idea how to open the remote.
The remote is a Toshiba CT-9854 and I can't find a way to get into it. No notches where you could use a screwdriver, no screws on the back of the remote. Slight twisting of the remote makes is look like the top somehow does come off. There is a tiny hole on the back that I thought may be a small screw, but it looks more like the reset button for a laptop.
Any information would be really appreciated.
