Help with the VSX45TX
Discussion in 'Archived Threads 2001-2004' started by David Harris, Nov 4, 2002.
  1. David Harris
    David Harris Stunt Coordinator
    Oct 31, 2002
    51
    I need help with then 45tx, i cant find the function to set the rear surround channels to bi-amp mode, is this possible on the 45 or is it just an option on the 43...tnx
  2. Harold A
    Harold A Stunt Coordinator
    Dec 16, 2000
    107
    David,
    What exactly do you mean by bi-amp mode? DO you mean that you want to bi-amp your rear speakers? If so are you doing this with an external amp?
    You need to give us more detail.
  3. David Harris
    Oct 31, 2002
    51
    I want to bi-amp the front speakers using the rear surround
    amps... when i was at tweeter 2 weeks ago i read through the vsx 43 tx and it showed this option in the setup for the rear surround amps along with b speaker option and 2nd room option tnx...
  4. David Harris
    Oct 31, 2002
    51
    the 45tx keeps shutting down at moderately high volume levels approx -3...any ideas, i have klipsch ref 3s w/ center and surrounds...tnx
