Help with Tempest LT
Discussion in 'Archived Threads 2001-2004' started by Griff, Aug 19, 2002.
  1. Griff
    Griff Stunt Coordinator
    Jul 6, 2002
    53
    Looking at the driver recommendations of the ESP website, a Tempest seems to be a pretty good choice for a LT. Are there any projects on the net using a sealed Tempest, an LT and a cabinet around 50-60 litres?
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I don't know of any projects with those specific parameters, but it should work pretty well. I'm going to use my Tempest first with my LT, but in 5 ft^3. 60 liters is very small (Qtc=~.9) and will require lots of correction/boost depending on Fc/Qc, so you can approach Pe at fairly low volumes and may experience some power compression. Probably be an extremely nice sub for much-less-than-reference levels.
    Have you plugged your numbers into the spreadsheet?
  3. Griff
    Jul 6, 2002
    53
    I have done a bit of research and have decided that i am better off with a Shiva in a 35litre, with a simple bass boost of 12dB at 10Hz, this will yield a pretty flat response and deep in room.
  4. Jack Gilvey
    Mar 13, 1999
    4,948
    Sounds interesting, just go easy on the volume.
  5. Griff
    Jul 6, 2002
    53
    What does go easy on the volume mean? Less then full volume? [​IMG][​IMG][​IMG]
  6. Mark Fitzsimmons
    Mark Fitzsimmons Supporting Actor
    Aug 18, 2001
    539
    Putting a 10db boost at 10hz puts you in some serious danger of bottoming the sub. I'd be cautious.
  7. Jack Gilvey
    Mar 13, 1999
    4,948
