Hey all, I'm going to upgrade from a 5.1 system with plain jane speakers on shelves etc. to a 7.2 in ceiling/wall. No biggie right? So the 2 subs (passive) require an external amp, 200 W each. So I've found a few amps that would work but... How are these amps turned on/off? They come with regular wall outlet plug ins, but I would prefer to wire them into wiring dropped down the wall. Being new to external amps, do they get kicked on/off when I turn on my receiver? Or do I need to run the wiring through a wall switch? Or are they typically remote operated, in which case they need to be exposed to receive IR signal vs my intended hidden plan.
