Geardaddys
- Mar 3, 2009
- John Miller
First post on the forum.. I recently bought a new television (Samsung LN46 A550) and a Sony Blue ray player to use with my old surround sound system. (Kenwood HTB 503).. I've never had a lick of trouble out of the sound system, but after hooking up my new TV, adding the Blue Ray player, and changing out my verizon FIOS box for a HD box (Lots of changes, I know) I now have an intermittent humming noise coming from my subwoofer. The hum goes away when I disconnect the subwoofer cable that goes to the receiver. It also diminishes with a reduction in volume, and crossover changes on the back of the sub. I've done a good bit of reading on ground loop isolators, and bought one from radio shack today. In reading the back of the package it says "Do not connect the isolator to speaker or video cables".. hmmm.. I was under the impression that the isolator connected in-line with the line out cable that runs to the sub? I don't think that I can use it anywhere else in my system as all of my connections are digital coax/hdmi/toslink..
soooo.. long story longer (sorry!).. Here are my questions:
A. Can I use this ground loop isolator (Radio Shack 270-054) in line with the "line out subwoofer" jack at the back of my receiver?
B. The line out at the back of my receiver is only a single RCA jack. The isolator is designed with 2 input/outputs on each end.. Radio shack dude sold me 2 Mono/Mono plug adapters that combine the two plugs on each side of the isolator into one RCA plug.. Do I need to use these, or should I just use the white or red plugs of the isolator?
Thanks for any suggestions for a home theater noob.. I'm certianly not a audiophile, just want to have "ok" surround sound without this annoying BUZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Thanks!
Thanks!
