Massimo N
- Oct 23, 2000
I'm trying to decide if I should spend the time to EQ my sub and I would like some feedback.
My sub is the SVS PB12-Ultra-2 with 1 port blocked (20hz)and located in the front corner in a small sealed room (approx 12.5'(w) x 18'(l) x 7.5' (h). The room is in my basement.
I have 2 Parametric EQs currently at my disposal ... one in my Pre/Pro (Anthem AVM30) and one in the sub's amp.
I think I'am getting a fairly a fairly decent response but I'll leave that to the experts. I don't know what type of house curve I should have, but un-eq'ed I'm getting a nice rise in the lower octaves.
Here are the numbers:
FQ--Measured-Adjusted
15-----76-----87.5
17.5---83-----91.0
20-----88-----95.5
22-----90-----96.5
25-----90-----95.0
28-----93-----97.0
31.5---88-----91.0
36-----84-----86.5
40-----86-----88.5
45-----87-----89.0
50-----83-----84.5
56-----85-----86.5
63-----86-----87.5
71-----79-----80.5
80-----78-----79.5
Any help how to maximize my EQs (only 2 available) would help. I would like to avoid buying a separate EQ if at all possible.
Massimo
15-----76-----87.5
17.5---83-----91.0
20-----88-----95.5
22-----90-----96.5
25-----90-----95.0
28-----93-----97.0
31.5---88-----91.0
36-----84-----86.5
40-----86-----88.5
45-----87-----89.0
50-----83-----84.5
56-----85-----86.5
63-----86-----87.5
71-----79-----80.5
80-----78-----79.5
Massimo
