MichaelDW
- Dec 2, 2001
I was thinking of putting a sub fireing into my aircondition return air box (where you change your filters)and build a box on the other side that would be in my attic,what do you think of this? or I have a fireplace with a slide in gas fire box self contained type unit, its in the corner of the room with a fake wall that runs up into the attic do you think I could put a sub at the top in the attic and have the sub firing down into the fake wall or chimney? the only problem I see with this is where the fire box is there is only a 1/4 inch or so where the air can escape or vent into the room. thanks for your help. michael
