JeffD
- Jan 21, 2004
I need some advice. I have a Sony STR-DA 50 ES receiver. I have not used the tuner until
recently. I have a single cable running from the Sub-woofer output to the sub. I noticed
when using the tuner with a sound field turned on I have a signal to the sub and it sounds good. But when I turn off the sound field I lose the signal to the sub.
I turned the sound field off to hear the music more like it was recorded.
If I connect two cables from the preamp out for the front left and right to the sub and disconnect the single cable from the sub output I get all the bass I ever wanted. But then If I try and watch a movie the bass is very low.
My questions are 1. Is this the way it should be working? And 2. would it hurt anything to leave all the cables connected which would give me good bass during a movie and then on music without a sound field also.
My concern is, if the sound field got turned on while playing music I would have a signal on the two cables from the front L/R and from the sub output. Could this damage my amp.
Does any of this make any sense?? I feel like I’ve started to ramble….
Thanks for any help!
Jeff in Wichita
Jeff in Wichita
