Eddie Sanchez
- Mar 15, 2001
I have all my stuff ready Velodyne Ct-100,Sony STR-DE845,JBL NSP1. Now can someone help me on how to setup everything. First the sub it has a couple of settings what should this settings be set to.
1.Low pass crossover it runs from 40Hz to 120Hz???
2. Phase 0-180 degress????
3. Internal X-over or Direct
4. Highpass crossover 100Hz or 80Hz
5. It has two inputs R and L do I have to use both or just one?? There are two LFE outputs on the receiver too???
The receiver what should the Sub volume be set to???
-10db +10db
LFE Mix - it ranges from 0db to -20db and Off
DTS LFE Mix 0db to 10 to -20db and off
Front speakers,center,and rear speakers can be set from 60Hz to 180Hz what should I set them to????
thanks in advance.....
-10db +10db
