Help with speaker decision for Denon 3802
Discussion in 'Archived Threads 2001-2004' started by Leon C, Jul 11, 2002.
  1. Leon C
    Leon C Auditioning
    Jul 10, 2002
    14
    I just took the plunge with that great deal on the Denon
    3802. Now I am trying to narrow down speakers. I plan
    to listen to the models that I can, but wanted to figure
    out what "packages" to ask about.
    I probably do a 50/50 split of music (mix of modern styles mainly as opposed to classical) and HT
    and will be using a living room with 10' ceiling and 18'x25' dimensions with some weirdly positioned (angled)
    side walls for the surrounds.
    My speaker budget is rougly $2500 and I figured on getting
    a SV Sub (PC model since I don't have a separate AMP) for around $600 -- that seems to be the subwoofer of choice, right?
    That leaves me about $1900 (I am not really going to consider shipping or tax, since $2500 is not a rigid value) for the mains, center, and surrounds. The brands I am considering that I can audition in local stores are:
    B&W
    Paradigm
    PSB
    Klipsch
    I am also considering Rocket and Diva. For the Rockets, I
    am considering the RS550 / RSC200 / RSS300 package for $1800 or the RS550 / RSC200 / RS150 package for $1700 -- any opinions on which surrounds would be better for angled side walls in a large rooM/
    For the Divas, I am considering the 6.1 / R3 / C3 package for $1900 and even gave some thought to the 4.1 / 2.1 / C3 package for only $1200.
    My question is what packages of speakers should I consider (with the $1900 max price) for the B&W, Paradigm, PSB, and Klipsch? Any other brands I should be looking at or have I hit the majors? Thanks.
  2. Russell _T
    Russell _T Supporting Actor
    Aug 26, 2001
    579
    The Rockets are pretty nice. I am using the 750 and 200 up front and the 250's for surrounds. For me, this combination just sounds fantastic. From a practical standpoint, I can't imagine needing anything better. I don't know exactly how much this combo package is, but whatever it is, you are getting audiophile sound for an unbelievable price.
  3. Brandon Blair
    Brandon Blair Stunt Coordinator
    May 28, 2002
    96
    Another option in that price range is the JM Labs Chorus line of speakers. The Chorus is their entry level speakers, their top line, the Grand Utopia's cost as much as $70,000 a pair. They have a good deal running through the end of the month where you can get their Chorus 725 Floorstanders, Chorus SR 700 surrounds, Chorus CC 700 center channel, and Chorus SW 700 sub, all for $1995. At retail they would cost a combined $2695. If you've never heard any of their speakers, JM Labs has a truely incredible product, receiving rave reviews in nearly all the magazines that have reviewed them. I would strongly recommend trying to check them out in person if you get a chance, here is the website for more info.
    www.focal-jmlab.fr
    Good Luck,
    Brandon
  4. Earl J
    Earl J Stunt Coordinator
    Aug 23, 2001
    101
    I think M&K has some great speakers that would fit your budget. I own the M&K 750 THX-Select speaker system. It sounds great for HT and music. Check out mksound.com
  5. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
    Paradigm studio 40, cc center and adp surrounds is a killer setup.
    B&W 600 series is a sure bet also, as klipsch ref line.
    you should hear them for youself to choose. win win situation.
  6. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    I am a Paradigm person myself, so I second the Paradigm reccommendation. But all the others mentioned are good as well. Make a list and start the audition process. Find what you like best.
  7. Michael Mathius
    Michael Mathius Screenwriter
    Nov 12, 2000
    1,439
    6
    110
    Before I upgraded my speakers I had the Energy Encores which I would highly recommend. If you are looking for small speakers with large sound then be sure to try the Encores.
