Help with settings on new HDTV decoder box
Discussion in 'Archived Threads 2001-2004' started by Theodore, Mar 25, 2002.
  1. Theodore
    Theodore Auditioning
    Feb 7, 2002
    14
    I have a Wega t.v. that automatically detects a 16:9 signal and I just got my decoder box. The box has a menu that lets you change the screen size to 16:9, 4:3, or 4:3 stretch. What should I set this to? Also, no matter what I set it to, the picture is not full screen. Is this normal? Thanks very much for any feedback.
  2. Kevin Coleman
    Kevin Coleman Second Unit
    Jul 3, 1999
    495
    You should set your HDTV box to 16X9 and then set your WEGA to 16X9 squeeze mode. However this will not fill your screen because your wega is not 16X9. But that is how it should be setup.
    What HDTV box do you have?
    Kevin C. [​IMG]
  3. Theodore
    Feb 7, 2002
    14
    I got it through TWC. It's a Motorola HDTV box. My t.v. is a Sony Wega XBR 450 32 inch. Thanks for the help.
