Chris Thompsonn
- Dec 26, 2002
Hi new to the board and was hoping someone could help me out...
I currently have a Pioneer Elite 49tx which works GREAT matched up with front and rear PSB speakers.
However I recently purchased a PSB subwoofer but I can't seem to get it to work correctly... Using Auto setup with the microphone the receiver does detect the sub however it is putting out very little if any sound. In fact unless you really turn it up it will automatically shut down after 15 min due to lack of signal...
Going through the setup menu it is detected and has a set output of -10db. Which seems appropriate it sits ~ 17ft from sitting area...
The only way I have been able to get around this is to set the front speakers to "small" which then directs all the base to the sub... I hate to do this since those speakers have a beautiful sound with great natural base I simply wanted to add the sub to give it more punch/feeling...
I'm sure this is not the best way to set up the sub however the documentation is pretty lousy... The sub is hooked up using a single wire from the receiver to sub nothing fancy and as per instructions...
Sorry for the long winded post...
Thanks for any help
Chris
Thanks for any help
Chris
