Help with RS 1994 and Panasonic RP-91
Discussion in 'Archived Threads 2001-2004' started by Gary_E, Jan 6, 2002.
  1. Gary_E
    Gary_E Second Unit
    May 6, 1999
    366
    I programmed my RS 1994 to code 0490 as per the instructions for Panasonic DVD players. Some basic functions work, scan, still, play, pause etc, as well as the menu navigation arrow keys but the 1994 will not power up/off the unit and the menu/audio buttons will not work.
    I tried to teach the 1994 the codes from tne 91's remote but the 1994 will not learn them.
    I'm using AUX1 copied from the VCR button on the 1994. I formerly used the same remote for a Toshib 5109 and it worked fine.
    I had seen a listing for the Panasonic codes somewhere but I just can't find the page now. If anyone has a link to the site containing these codes, I would greatly appreciate your assistance.
    Thanks in advance,
    -Gary
  2. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    110
  3. Mike_A
    Mike_A Stunt Coordinator
    Oct 7, 2001
    153
  4. Gary_E
    Gary_E Second Unit
    May 6, 1999
    366
    Thank you gents!!
    I forgot to SEARCH the HARDWARE ARCHIVE section.
    -Gary
