Mike Dr
- Jul 30, 2000
Mike those actually look like they would spin when you try to take them out. They don't look like they will grab the wood very well. Or did you glue them in the hole?
Actually, the female (long plug) side of it has little teeth for about 3/8" of the run so when you put it into the wood, it holds fairly well, but both of the sides have a phillips head so you could use 2 screwdrivers. For me, the pilot holes were tight enough that the receptacle part held in place by itself quite well and did not present any problems.
