Dereck Graefer
- Oct 13, 2002
Hello Everyone!
This is my first post here, and I am wondering if someone can help me out with some suggestions, info, etc.
I recently purchased a set of JBL S310II towers connected to a Denon 1602(70w x 5) receiver. Right now I just have the Front towers. Everything sounded good when I initially set them up. I found that having the volume on the receiver set to 00 was about as loud as I want to listen to music. (The receivers volume goes from -60 to 00 to 18). Im only about a meter away from both speakers so the volume at about 06 hurts my ears. Now, the other day I was listening to some classical music and I noticed that the tweeter in the left tower was spitting out a fuzzy noise type distortion when playing high notes. I turned the receivers volume down to about -30 and the noise was audible if I moved closer to the speaker. I played some different music genres, and the distortion was present, but not as pronounced as with the classical. The mid and sub sounded fine. What I found odd was that the right tower was playing clear as day - at any volume level. I swapped the channels for the speakers, and the noise still came out of the left speaker, even though it was connected to the right channel. So, Either the tweeter was damaged when I bought the speakers, or I damaged the tweeter myself. Could my receiver have been clipping and damaged the tweeter? How probable is it for a receiver like mine, to clip on the speakers when volume is at 00? I was told by the salesperson that this receiver was powerful enough and would work well, but now im not too sure about that. I'm going to return the speaker at some point, but want a few questions answered first. Do you think I need a higher powered receiver? Or do you think my receiver is fine and I just need to replace a defective speaker? Any suggestions/comments/hints/etc. Also, if it is the case that I need a new receiver, suggestions for a new one would be appreciated. Something in the $400 CDN range would be optimal. I am planning to get a full HT setup as time goes on, so that should be considered with everyones suggestions.
- Thanks
- Thanks
