Joseph_Mikhail
- Mar 26, 2002
I have a HK520 and a PA4000 4-channel amp (on the way). For now I will stick with a 5.1 setup. Should I use the amp to run the center and mains. Also should I biamp the mains back through the receivers internal amps?
I believe the 520 has two separate internal amps (one for the mains and center/one for surrounds).
