BillyJClark
- Sep 17, 2003
Someone please help an HTPC newbie with setting up powerstrip for a Sony 57HW40 RPTV.
These are the current settings that I have saved in Display configurations, but when I unplug my monitor and switch to my RPTV, I get an unstable (sometimes I can barely make out the moving, jittery image, sometimes it is just red, green, blue "streaks" before I turn off the TV and start over again.
Following the instructions from all the guides on this (and the AVS forum), these are my current settings.
960 X 540P - this is the resolution used in the "walkthrough" from
Horiz Scan Rate = 33.743
Vert refresh rate = 59.934
Vert total lines = 563 lines.
I also tried a 480P resolution, with no results either
640 X 480P
Horiz Scan Rate = 31.549
Vert refresh rate = 60.093
Vert total lines = 525 lines
The especially frustrating thing is that (and I know that I was advised NOT to hook up to my TV first) when I first received my Audio Authority VGA to Component adaptor, I went ahead and plugged it in (maybe 800 X 600???), got a good picture, DTS through to my receiver, and everything worked. As soon as I added Powerstrip and began altering resolutions and scan rates, I can't get any image that is stable (even after uninstalling powerstrip and trying to return to a usable image).
I guess sometimes the unavoidable urge to tweak or improve something can be our downfall (but I know it can look so much better)!
Any help on this would be greatly appreciated. Also, not sure if it matters, but I am using an Nvidia GeForce3Ti Mx 200, but also could install a GeForce2Mx (or a Radeon All-in-Wonder, but I want a separate tuner card that will work with Dscaler).
Billy
640 X 480P
Billy
