Matt D K
- Dec 17, 2002
My enclosure is just about finished. I am in need of some help with the port size/frequency.
The net volume(not counting port or speaker displacement) is 6522 cu inches/106.876 liters. I am using the PE 250 watt amp. My main speakers are Polk LSi15's which have an 8" woofer and play nicely down to about 50hz or so. My room is about 16' x 17' with 10' ceilings that vault to about 14', there is no rear wall. I primarily want it for home theater use, but still want it to play music well (mostly classic rock / modern jazz / and country) I THINK i want to tune it to around 18 - 20hz, unless someone tells me why I shouldnt. I will be using the 4" flared port firind down onto a base plate mounted about 4" from the bottom of the cabinet.
Thanks for any and all help!
Matt
Matt
