Help with picking display!
Discussion in 'Archived Threads 2001-2004' started by DerekF, Sep 19, 2002.
  1. DerekF
    DerekF Stunt Coordinator
    Nov 26, 2001
    184
    When I built my house, I built in an AV cabinet with access from behind. It works great now, with my 32" Ultravision....but...
    I'll need a new TV soon, and I don't know what to do, because the cabinet I built is only 40.5" across, meaning I'm limited to either:
    A 36" Wega
    A 43" RPTV
    or....
    I could put a big screen over the opening, and go with a projector...the problem with this is the room layout though: It's a 10.5' x 14' room adjoining a larger (pool table etc.) area...and the TV is on the 14' side.
    Is 10.5' too close for a projector?...thoughts?
    (room is like a capital "B". with smaller upper area for HT, lower area pool table)
    Thanks!
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    The max screen size I would recommend for FPTV at a 10ft viewing distance is a 16x9 screen 72" wide or a 4x3 screen 86" in diameter and with a projector that has a resolution of 1024x768 minimum (of which there are many). Even better would be a projector with a native 16x9 resolution like this one...
    [​IMG]
    Boxlight Home Cinema 20HD
  3. DerekF
    Nov 26, 2001
    184
    FPTV newbie here....so that's 72" wide for 16x9, but larger width for 4:3? or did you mean 86" diagonal?
    thx!
  4. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    You have to think about the light in your room. Can you darken the room sufficiently for a front projector to work during the daytime?
    Also, remember that you'll be buying bulbs in the $200-400 range every 2000 hours or so, so you might not want your kids watching Barney and such all morning and putting a lot of mileage on the bulb. Keeping a smaller direct view set in that spot for "ordinary" watching, and reserving the front projector for DVDs, might be a good idea.
    Otherwise, I have to say that I love my 42" widescreen Toshiba. My room is smaller than yours, however, with about an 8' viewing distance. A small RPTV could be a decent compromise.
    Jan
