Michael1
- Oct 11, 2011
- Michael Portantiere
Hi, all. I have two Sony remotes, one for my "AV System" (amplifier, radio, etc.) and another for my Blu-Ray player. Both of these components, and of course also the remotes, are many years old, and neither of the remotes works fully anymore. To be more specific, while some of the buttons on the remotes work fine, others seem to have stopped functioning completely. And here's a weird one: Some buttons need to be pressed SEVERAL times before they finally work. (I really can't figure that one out, because I would think it should be a simple "yes" or "no" as to whether a button still works, not "Yes, but you have to push the button about five times.")
I do have a third remote, for my TV/monitor, but that's a far more recent acquisition, so the remote works perfectly.
My question is, what would you all advise as my best option for dealing with the problems in the other two remotes? Of course I'm aware of universal remotes, but I have never had one in my life, so I'm reluctant to go in that direction. Should I just get over it and buy one of those to operate the AV system and the Blu-Ray player? Are the universal remotes easy to program, and do they work with any component you program into them?
I'm assuming there's no place I could bring or send these remotes to be fixed, so would another alternative be to try to find replacements for these specific remotes online? I'm guessing it's HIGHLY unlikely I'd be able to do so, as the AV system is at least 20 years old, and the Blu-Ray player not much younger than that.
Any advice would be greatly appreciated; thanks so much in advance.
