Allen Gentry
- Dec 29, 2001
I read the newbie section. I have a slight grasp on what's being discussed, but don't really understand it in real world meanings.
I'm currently looking at replacing both my receiver and fronts, center, and subwoofer. The financials prohibit buying all at the same time. The components being replaced were from a Phillips HTIB. Currently, my speakers are rated at 4 ohms. The sub is passive. My room is small, square, with a raised ceiling and hardwood. We sit about 10 feet from the TV and SS.
Most receivers seem rated at 8 ohms. I know there are receivers that can switch between 4-8 ohms, but within my budget, nothing is available. What happens if a buy an 8 ohm receiver and continue using my 4 ohm speakers?
Some speakers I'm looking at are 6 ohm. Are those OK to use with an 8 ohm receiver?
What about my sub? It's passive. Most receivers say they have a "pre-amp" out for the sub. Will mine not work since it relies on my current receiver for power? I'll need a new "powered" subwoofer?
I wish I could aford some high dollar stuff, but this is all entry level. It's still a step up though. My receiver only decodes Pro logic, and my speakers only handle 40 watts or so.
Opinions on the Aiwa AV-D58? That's what i'm looking at. Seems fine for my application. I'm also looking at Yamaha's NS-6390 3 way bookshelf speakers with the NS-AC40X center, or possibly going with a satellite/sub set up like Yamaha's NS-P220.
Thanks for any help.
Allen
Allen
