SamCK
- Nov 24, 2003
I built this room about a year ago, and am just now starting to finish the home theatre. Any suggestions appreciated. The room is about 25 feet long (screen at front) by 11 feet wide, and 8 foot ceilings. The contractor wired satellite feed to front of room (near floor), electrical outlet for projector in mid ceiling about 17 feet back - but only wired a single coaxial cable!, sub woofer output at right rear of room, surround sound speakers right and left about 17 feet back in ceiling. The entrance in in the back on one side, as you enter, there is about 9 feet of back wall to your right. I am thinking of putting a 9X5 riser here for two seats, and put another three seats in front.
I'm having it wired this week. I plan on S-video, Component feed, and computer monitor feed from front of room to projector. I have a Infocus X1 and Draper Luma Screen (120 diagonal (69X92).
My questions.
1.Should I wire anything else to projector. I plan on running it through ceiling joists to side of room, down to floor, and then removing the baseboard and cuttinga hole in the drywall to fit the cable and reattaching the baseboard) to complete the run to teh front of the room.
2. Is a right rear location the best for teh subwoofer?
3. Is this equipment OK. I know the projector is cheap, but I've read good reviews and plan on upgrading.
4. Where should I mount projector - distance from front and height from ceiling. Can this project a decent 120 diagonal image? The manufacturer suggests 16-18 feet for a screen this size.
5. Where should I mount the screen - height from ceiling and floor. I plan on building a cabinet underneath for my equipment.
6. Is my seating arrangement OK. Any suggestions on riser height? I'm concerned aboiut vieing height and screen height.
Any, and all, suggestions welcome. I haven't started the final stage... so rip it apart if you like!
My questions.
